Discuss IDEAL are up against it!!! Heat exchangers replacing in the Plumbing Jobs | The Job-board area at PlumbersForums.net
At least i have a good company nearby to do the fitting and servicing. Been going a long time.
Pretty much set on a Vogue now, they seem to modulate very low as well. Just need to pick a size now.
The size you need is relevant to the amount of hot water you require. A 32 will do most properties but if you have a few bathrooms the 40 is better
Reactions: Dan
Have fitted the Logics since there release and I have had maybe two heat exchangers fail in that time. Both were under warranty so changed no problem. We check by introducing food dye into the radiator and see if it turns up in the condensate trap
so would none of you suggest an ideal boiler?i posted on the forum as wanting advice for a replacement combination boiler, the plumber came round and he's a official installer for ideal..i did think worester but he says ideal were better..this is for a 3bed det house with 1 bathroom and replacing a feroli which is 14 yrs old
i wouldnt if you are looking to use there warranty service / aftercare
worcester all day for me
worcester 30i or 32i?weve had a quote for ÂŁ3660 to replace our boiler with a combination worcester with 6 replacement radiators..a new control box and thermostats on all the radiators and a magna flush..is this quote about right or are we being taken for a ride? Thanks
Eh?
check the condense, its going out there through h/ex when it gets hot
Interesting this, I've only come across 1 that has failed and presumed it was a one off but sounds like it's a regular occurrence. The 1 I seen was leaking into condensate when boiler cold, so can it start leaking when it gets hot but stop when it cools down?
Ditto have fitted them since first out and only had one hex replaced- this was a concern as it was fitted 2011, hex went 2015. But so far no more. I hope no more as have fitted 50 plus.
I have only come across 2 they say it was on the early logics time will tell i guess but if you come across a system loosing pressure for no apparent reason check the Hex out cheers kop
Reply to IDEAL are up against it!!! Heat exchangers replacing in the Plumbing Jobs | The Job-board area at PlumbersForums.net
PSxxxxxx
