Discuss IDEAL are up against it!!! Heat exchangers replacing in the Plumbing Jobs | The Job-board area at PlumbersForums.net
R
REDSAW
to just bring to light the problems Ideal are having and why they are trying to default on their warranties for their boilers.
picture says it all really and this is just one example of a heating engineers typical weeks work !!:thumbs_down:
thats TWELVE heat exchangers that have failed, and there not cheap!
Bumped into a ideal engineer in plumb centre as they do system work, he was picking up a 3 port and he said they are flat out with changing them, I thought you should not be telling me this, as the guy in front was in the process of buying an I mini, he just left laughing.....
Not good to hear
doesnt surprise me
i use to fit them all the time but this winter has shown a lot of problems with the current range.
No matter which boiler i search for there are bad reports. I cant get a conclusive "this is best"
What draws me to the Ideal Vogue is the stainless exchange, and Opentherm.
Such is life. No group of people will be happy about the same things.
Ask 20 engineers which boiler to fit and you will probably get 20 answers.
The trick is finding the right one for yourself.
Important things for me would be :-
1. Who's fitting it. If there is an issue I want somebody local who will answer the phone, not one of these national companies who you are only a number on a database.
2. Availability of spares. Everything breaks down, but I don't want somebody telling me I have to wait 2 weeks for the flux capacitor.
3. Not a worcester, but that's just my experience with their customer service on the oil side.
At least i have a good company nearby to do the fitting and servicing. Been going a long time.
Pretty much set on a Vogue now, they seem to modulate very low as well. Just need to pick a size now.
Talked that up Redsaw logic+ 24 pressure dropping no sign of leaks , luckily not one of mine let through a estate agent service and landlords my take a bit longer now
Eh?
check the condense, its going out there through h/ex when it gets hot
yep done that bud another HE for the scrap heap , if that was not bad enough had to have trans co out change the meter and regulator hay ho tomorrows another day
The size you need is relevant to the amount of hot water you require. A 32 will do most properties but if you have a few bathrooms the 40 is better
Reactions: Dan
Have fitted the Logics since there release and I have had maybe two heat exchangers fail in that time. Both were under warranty so changed no problem. We check by introducing food dye into the radiator and see if it turns up in the condensate trap
so would none of you suggest an ideal boiler?i posted on the forum as wanting advice for a replacement combination boiler, the plumber came round and he's a official installer for ideal..i did think worester but he says ideal were better..this is for a 3bed det house with 1 bathroom and replacing a feroli which is 14 yrs old
i wouldnt if you are looking to use there warranty service / aftercare
worcester all day for me
worcester 30i or 32i?weve had a quote for ÂŁ3660 to replace our boiler with a combination worcester with 6 replacement radiators..a new control box and thermostats on all the radiators and a magna flush..is this quote about right or are we being taken for a ride? Thanks
Eh?
Interesting this, I've only come across 1 that has failed and presumed it was a one off but sounds like it's a regular occurrence. The 1 I seen was leaking into condensate when boiler cold, so can it start leaking when it gets hot but stop when it cools down?
Ditto have fitted them since first out and only had one hex replaced- this was a concern as it was fitted 2011, hex went 2015. But so far no more. I hope no more as have fitted 50 plus.
I have only come across 2 they say it was on the early logics time will tell i guess but if you come across a system loosing pressure for no apparent reason check the Hex out cheers kop
Just make sure that they fit the Gen2 version of the Vogue. Few extra little tweaks in it, few bits ironed out and a really nice colour display too.
Jon
Worcester for me or Viessman look good. Just did their installer day course and I was quite impressed. Very easy to repair and can come with a 10year warranty for an extra ÂŁ100. They have a stainless steel heat exchanger.
I've installed 100,s logic and vogue never ever had a hot water heat exchanger fitted yet! It's all about the engineer doing the job simply do it properly flush thoroughly magna clean, in line descaler on every fit mini expansion on the cold if water meter or check valve..yep I'm expensive on my installs but it's done right...if customer wants to go for cheapest quote best of luck to em I get plenty of work!
Couldn't agree more! Although this is the main Hex.
Not sure whether to like this or agree?
Jon
Slip of the thumb bud apologies didnt mean to press the dumb button regards kop
Or why not look at discolouration or smell the condensate water
The one vogue I fitted, there was a tremendous amount of plume. Even had ideal out to it who said it was completely normal.:mad::mad:
I like the vogue , but if a system is looked afer or fitted great then problems will arise,
But good point from simon , every engineers opinion and experience is different,
Interesting to read this! My local man, in the trade for over forty years and with a very good reputation in this area recently fitted an Ideal for me. Having read about the comments about having a water meter fitted and the the back up problem I asked about having a mini expansion vessel fitted. He was unaware but contacted Ideal and they said not a problem with a long distance from main to boiler. But they sell the very same piece of kit! So why if not needed?
Because on some installs the cold water run from the meter will not be long enough and you could get problems. This is true of any combi not just Ideal. It's just that Ideal have identified the problem and have a kit available to sort it
Reply to IDEAL are up against it!!! Heat exchangers replacing in the Plumbing Jobs | The Job-board area at PlumbersForums.net
PSxxxxxx
