Discuss i need to pick your brains. wheres Simon F lol in the Plumbing Jobs | The Job-board area at PlumbersForums.net
scottyblen
when it comes down to heat and calculating the amount of heat required 60 mins X 60 seconds=3,600 gives me the number of seconds in an hour right?
the book i have been reading from states "1000 joules over 1 second X 3,600 (number of seconds in one minute)
i am lost.
The amount of heat required for what? Give us a clue and you will get an answer.
i just didn't understand that part of the text in the book.
the specfic heat capacity 4.186.
lets say there is 150 lts of water the current temp of that water is 4 degres C. I want to get it 80 degres C.
so thats 150 ltrs X 4.186 X (80 - 4) = 47,720.4
47,720.4/ 3600= 13.26 KWH
Right i better find the calculator then :smile:
Q = mc⌂T
m = the mass (in this case 150 litres)
c =the specific heat capacity (water is 4.186 joules/gram (or watt/seconds))
⌂T = the temperature rise (in this case 76°)
Your mass should really be converted to grams (1 litre is a kg so needs multiplied by 1000) but don't do it here unless you want the answer in watts as it is easier and would need converting back.
so
150 x 4.186 x 76 = 47720.4
this answer is how many kw you would need to raise the temperature of 150 litres of water by 76°C in 1 second which is useless to you as you probably want to know how long it would take a 3kw immersion to do that
so
divide 47720.4 by 3(for a 3kw immersion) = 15906.8 then divide that by 60 (seconds in a minute) = 263.11 minutes to raise the temperature
Q = mc⌂T
so
so
you have lost your mears,or are sober LOL
Reply to i need to pick your brains. wheres Simon F lol in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi there, thanks for your time to look at this record long post!! I work on the operational management side or a small building contracting firm...
H
HRP123
H
Not sure if this is a success or a fail or just a rant but We do have heat and hot water now So all started the evening of Friday the 12th (Nov)...
2K
Hi, I have a an IDEAL ICOS HE 15 boiler that was fitted in 2005 to a new build property and in general it's been pretty reliable over the years...
2K
