Discuss how to get into this tap in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Jennie
Hi all,
Does anyone know how to get into this tap? I need to check the washers - it's got a drip. There are no grub screws on the tap heads. The tap head/upper cylinder are one piece. So I tried to undo the lower cylinder around the tap body, but it's not shifting - I'm wary of scratching the chrome finish.
There must be a magic solution (or so I'm hoping).
Jennie
Is that the bit directly under the handles? Or the cylindrical parts closer to the tap base?
Much thanks,
Jennie
hello Jennie,
Can I ask how you managed to strip this tap down? I have the same taps and need to stop them dripping. As you say, there are no grub screws. The chrome section closest to the base appears to simply be a cover as it spins freely. therefore the section below the tap (which moves with tap) may be the answer. I just want to be sure before I start forcing anything.
Cheers in advance - Tony
Reply to how to get into this tap in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi bit of a weird issue, I installed a grohe bathroom tap successfully 2 months ago bought from screwfix. Last week the right hand hot tap makes...
