Discuss How to change blanking plug valve on heated towel rail? in the USA area at PlumbersForums.net
ade
Hello team,
I just noticed that in one of my bathroom, the blanking plug valve on the towel rail is leaking. I just moved in this new house and the valve looks old and the seal a little damaged. Anyway, I just ordered a replacement but I have no idea on what is the process to change that. What valve should I turn off to stop the water pressure and unscrew the old valve so I can replace it?
I can share pictures if needed.
Many thanks!
Shut the radiator valves
Upon the bleed/vent plug to check they pressure drops off and the valves are holding.
Grab some old towels and swap the leaking plug.
Hey Scott, many thanks for your reply.
So, if I got that properly
1. Be sure that the radiators are cold
2. Turn off the valve of the single radiator (the left one on the attached picture I guess?)
3. Open the bleeding valve and let spill go, if the valve is holding it should stop in few moments
4. Remove the blanking plug and swap it with the new one
Am I correct?
The valve on the right is a lockshield. When closing, count the number of turns. Afterwards reset the valve to the same position.
Thank you very much!
[automerge]1605804499[/automerge]
I am having some difficulties on removing the myson valve you can see at the right, it only has one Center screw but is very tight. Does it needs just a bit of WD40?
Reply to How to change blanking plug valve on heated towel rail? in the USA area at PlumbersForums.net
My towel rail is not electric but separate to central heating and has been working consistently but since the 2 port valve was replaced on Monday...
Hi I’ve got a blockage somewhere that’s preventing the GCH bathroom towel rail from heating. Plumber has offered to try and resolve it at...
Deleted member 120897
I'm going to have my bathroom renovated and that includes changing my rusty old rad for a towel rail. I wanna cut down the costs as much as...
Hi guys, These sleeves cover 10mm PVC central heating pipes (see picture and ignore tape measure) and I believe this is what makes it possible...
