Discuss How to bleed Y plan system? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
hi everyone,
I’ve just changed my circulation pump and I only noticed before re-fitting that the diverting valve was set on HW.
So I must’ve drained the HW side to just below pump level?
Then I refilled and turned it on.
Is there any way I must bleed it now as it’s the HW side?
Sorry if stupid question, thanks!
Put valve into mid port
Bleed any air vents around the cylinder area
Turn system back on electrical put port valve off manual
Turn both heating and hot water on
Let pump run for a while then bleed pump via centre screw
Then bleed pump
Leave 24 hours unless problems
And air any air vents again
Just remember: air always rise above the water that is why air vents are placed at the high points, if you 3 port valve is a spring return type it will return to the HW position when power is off.
Reply to How to bleed Y plan system? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
