Discuss How to bleed Y plan system? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
hi everyone,
I’ve just changed my circulation pump and I only noticed before re-fitting that the diverting valve was set on HW.
So I must’ve drained the HW side to just below pump level?
Then I refilled and turned it on.
Is there any way I must bleed it now as it’s the HW side?
Sorry if stupid question, thanks!
Put valve into mid port
Bleed any air vents around the cylinder area
Turn system back on electrical put port valve off manual
Turn both heating and hot water on
Let pump run for a while then bleed pump via centre screw
Then bleed pump
Leave 24 hours unless problems
And air any air vents again
Just remember: air always rise above the water that is why air vents are placed at the high points, if you 3 port valve is a spring return type it will return to the HW position when power is off.
Reply to How to bleed Y plan system? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello. I've just replaced our old Potterton EP2 CH controller with a Drayton Wiser HubR (& peripherals). The old backing plate wasn't compatible with the new universal one, but the wiring was pretty close AFAICT (N, L, 1, 3 & 4 connected) .When I first powered it up but didn't have any TRVs...
Oil boiler (now~15 years old) unvented system with 17 radiators. We moved in 5 years ago and I had to keep bleeding the same radiator. The bleed gas could be burned with a blue flame and the water was acidic (pH 5.5). Since then system has been chemically flushed (it was not too bad) and the...
Hi, I seem to have lost a bleed nipple from one of my rads somehow. It’s a double rad, one side of the rad has a nipple, the other is gone and I need to bleed it to stop the bubbling noise. How can I fix this please? Is it possible to buy a new one and if so how do I know what to ask for...
Customer complained of hot water tank getting hot when no demand Y plan system couldn't see any issues so I watched it Timer set to CH only, HW off Thermostat turned to on Heating comes on as normal, valve moved to CH position After around 20 minutes the 3 way valve moves to mid point and...
2K
Hi All, Looking for a bit of advice on the best way to pipe this. - 24kW Worcester regular boiler in kitchen, approx. 9 years old - unvented tank, zone vavles, pump, expansion is on first floor in airing cupboard - Currently piped as S-plan. - Hive controls. - Would like to fit 6-zone...
