Currently reading:
how do get the top off !!
Discuss how do get the top off !! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
G
gravytrain
hi all
got to fit some tap revivers, but i cant see how to get the top off the tap
i've only looked at it but i thought i'd put a photo on in case anyone has seen these taps before
and knows exactly how to get the tops off before i go round and have a go myself
thanks in advance
Looks as though you might have to hold the red bit with plier's then twist head anti-clockwise
Pull hard and straight up, but move anything breakable from above. Try rubber gloves for a better grip.
If you are replacing spindles and new heads you could just force them off with grips
they'll want tops back on to match bath taps!
now thats the difficult part those tops are very unlikely to fit the splines on your tap converters ,it may be worth taking the valve apart,re-greasing the worm and fitting new washers but if its badly worn that wont help
These taps are part of one of the most successful bathroom suit ever,the ideal standard studio,original version
They just pull off as said,you can still order tap inner's and heads from ideal
imho
problem solved thanks to puddle,do you ever forget anything puddle? good memory:crazy:
hi all
thanks for all the advice
its my last job tomorrow, with any luck it'll be nice and easy and i'll be home by 4.30 LOL
hi all
or you will rip the basin off the wall and burst the pipes and break a tile and plaster off the wall and not have any blank caps, and have to go to B&Q and cry at the prices, just to do a temp repair till 3 of you go back again tomorrow
i use a little teasing from a fat screwdriver underneath, if i remember right, the splines are vary wide (10mm)so doubt reviver will fit?.
Reply to how do get the top off !! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
