Discuss How can I remove this flush valve? in the DIY Plumbing Forum area at PlumbersForums.net
I've got water trickling into the pan of a toilet. The cistern water level is nowhere near the overflow pipe, so I suspect there's a faulty seal at the bottom of the flush valve (a Geberit model). However, I am unable to detach the flush unit to check. There don't seem to be any side clips to press. Also, I've tried rotating the flush unit, and it moves about 90 degrees, before jamming against the cistern walls - but I have noticed that, while the main body of the unit turns, the pedestal of which it sits remains stationary (I've tried twisting the pedestal directly, but it won't shift). I've attached some photos to clarify.
Any ideas on how to remove this unit?
The bottom part is fixed don’t try and turn this as will end up splitting the toilet to retighten it
Reply to How can I remove this flush valve? in the DIY Plumbing Forum area at PlumbersForums.net
