Discuss Hot air heating system. Easy to remove? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Saz8008
Hi, I have just bought a house with grilles from a hot air heating system however we also have a combi boiler and radiators so the system is now redundant and has been closed off. I want to knock down a cupboard between two bedrooms but there is a grille at the bottom of the wall each side. When we take these walls down are we going to find any piping etc which wil prevent us building a new stud wall?
Hi Saz,
My Mother had hot air heating, when that was removed just had air ducting which was cut back enough to brick and plaster.
You may find an old plenum box or a bit of ducting. Just pull it out. It will be joined with self tappers or pop rivets.
many of these systems had asbestos panels on the cupboards etc, please take care before ripping the place apart, there was also asbestos in many old appliances and flues as well
Aye, try not to breathe!
Seriously though, as Kirk says, take care in case of asbestos, at the very least use no power tools and wear respiratory and eye protection. the less dust you create, the better.
Or, although it's pricey, get an asbestos company in to give the area a once over. depends how much you value your health in the long run!
Reply to Hot air heating system. Easy to remove? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
Hello, We’ve recently moved into a fairly old, fairly big detached house (i.e. fairly draughty, but not too bad by any means) with a fairly new...
MartinPod81
M
Good afternoon, I am experiencing a pressure issue with my heating system and was hoping to receive additional insight as to what the problem...
B
Issue with boiler short cycling in system with hot water tank. We have an ideal heating logic heat2 h15 boiler which feeds a hot water tank...
Hoping for some advice as I seem to be hitting a brick wall. Moved into a house last year, radiators down strairs (4 of them) never really got...
Hi everyone. I'm currently working on a job for a customer. their radiators are not all heating up. in total there is 12 radiators. 4 of these are...
