Discuss Hercules Direct Copper (IMI Range) Immersion heater went bang in the night in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
maggie
Dear Forum
Economy 7 immersion heater went bang in the night. It is an Hercules Dirrect Copper Cylinder IMI Range with two switches (it is about 20 years old) one at the bottom and one at the top. I have the bottom one switched on all the time as it stores during the night. I still have hot water at the moment and it is very hot. Shall I switch off both switches and wait for the water to cool and see if I can use the top switch (the boost switch) until I have it checked? I also have a power shower fitted. Will this be affected by the dodgy immersion heater?
Also for the past few months I hear load banging noises which seem to come from the loft or the immersion heater. It's sounds as though something is going to explod.
I live in Milton keynes and have a one bedroom house which is all electric. I also have an old style electricity box which uses wires in the kitchen.
It would be helpful if anyone knows of a trustworthy plumber/electrician in my area.
Not sure whether this information makes sense or not.
Thank you.
Hi & welcome to the forum, yes it just about makes sense except the bit about wires in the kitchen. You do need to get someone in to get it all checked out, it is likely the main (bottom) element has blown & will need replacing. The top boost one will only give you a small amount of hot water unlikely to be enough for anything other than the quickest power shower.
You should switch & leave on the boost & switch off the lower, then see if you still have hot water tomorrow.
consumer unit and fuse wires. wouldnt be a bad thing to have a sparky check your electrics esp if you have a power shower.
Reply to Hercules Direct Copper (IMI Range) Immersion heater went bang in the night in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All I have a leak coming from within my Mira Elite QT shower. It seems to be flowing from behind the switching Control. Any ideas what could...
