Discuss Help with Hep20 connector on shower inlet in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Could do with advice on how to disconnect what I think is an old grey Hep20 connector.
Elbow connector connects direct to the electric shower inlet. Elbow then connects to another elbow via short piece of pipe (so short hardly any is visible between the two elbows).
Question is, how do I get the elbow off the inlet so as to replace the shower! Help!
Photo attached as above description isn't great!
Thanks.
undo the collar eg the bit with knurls turn that to the right until its unscrews
should be easier with the shower loose eg not screwed / fixed to the wall
Yes there still available
Or if the shower is broken cut the plastic spigot and pull the plastic spigot through
If that makes sense
Not now same Shaun. Are they entirely compatible when swapping bits? OP needs to be exceptionally careful removing andcdef needs new Oring as it will be deformed now.
Every joint will be the same as the first so you will be stuck with what you had after dismantling the first one.
1. The old Hep requires a small tool to release the grab ring, but you have no room to loosen the nut to get the tool in, even if you could get the tool.
2. I don't think you have any option but to cut the fitting off with a hacksaw. Cut through the nut on the visible side, rotate it and cut through the other side. Remove the nut and you should be able to slide the elbow part of the fitting off from the front of the pipe. Use a pair of cutters to cut through the green plastic shield for the grab ring, then cut through the grab ring. The remains of the fitting should then come off the front of the pipe. Clean the pipe up and you should be able to use a brass compression elbow for the new shower.
Reply to Help with Hep20 connector on shower inlet in the Plumbing Jobs | The Job-board area at PlumbersForums.net
