Discuss help on a 105HE in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
chunkauli
hi guys a bit of advice please
i have a baxi 105HE having intimate hot water issue it is flashing 70 which means fault on hot water sensor i have just changed the diaphragm but it is still doing it the only other cause which i believe is the thermistor or a block on the heat exchanger , can you guys shed some ideas for me to try and investigate??
:D are you gas safe if your not naughty naughty time to get a gas safe eng in
thats right no does it mean i cant work on my own boiler in my own hose ??
unless your gas safe you cant work on any gas appliance
i used to work for a company that was corgi registered and i'm competent enough to work on my own boiler ..is it still illegal ? i always thought it was ok ,thats what my service engineer said
nope as i have said you cant work on any gas appliance unless your gas safe not even your own
Reply to help on a 105HE in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I'm hoping someone here may be able to help me out with an issue I have with my baxi duotec boiler. Basically, the hot water temperature has...
I have a Worcester Greenstar gas boiler circa 2017. There has been a noise coming from the boiler which resembles running water, I have checked...
A
Hey, here goes and I hope it works.. never used one of these before! I have a Sagittarius Ergo mixer shower min bar of pressure required 1 bar...
  • Locked
Hello, I have a ferroli falcon 2 boiler (yes it is pretty old). A few days ago the hot water started going hot and cold when running. Monitoring...
