Discuss HELP. Boiler/heating/hot water not working! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Alright basically I shut off and drained a radiator pipe so I could change a valve and after I put it back together I expected to be able to just bleed the system... however the whole hot water and heating system just stopped working, no pressure at all when I try bleed the radiators & boiler just goes red light when I try switch on... any help?
Have you refilled the system?
No it’s not a combi boiler, i found out that the ball valve at top of house above water tank was stuck so I released it and all the radiators have pressure and bled fine... the boiler started to work... but again stopped straight away! The system seems fine but the boiler just doesn’t seem to be powering properly... it shows one green light but no ignition lights
Reply to HELP. Boiler/heating/hot water not working! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Heating and hot water is not working. Plenty of heating oil. I have replaced batteries in thermostat and it seems to be working ok, showing flame...
Hi all, Looking for some advice please. Got a building, all one level with 7 radiators. 3 individual ones in separate rooms then 4 radiators...
K
We have a dual heating system, a solid fuel stove with back boiler and a external kerosene heater. The kerosene heater is working fine heating...
How a thermal store boiler works! I’ve got an old thermal store boiler and I’m trying to work out how it works. From what I understand the boiler...
M
Hello, We’ve recently moved into a fairly old, fairly big detached house (i.e. fairly draughty, but not too bad by any means) with a fairly new...
MartinPod81
M
