Discuss Help!! Another New Boiler Question to replace an old Vokera Syntesi 25 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
G
gseaman
Hi All,
I know there are many posts on here asking for advice on 'which new boiler should I get', so hoping you can put up with the tedious subject one more time and help me out
Needing to replace an old Vokera Syntesi 25e so I've had a couple of local companies round to give me a quote, and also looked at some of the companies online such as BOXT. I've tried to do a little research but overwhelmed with what's out there.
One quote I'm very interested in is for an ATAG IC 28 with the One Controller, which with the efficiency and 10yr guarantee (lifetime on heat exchanger) all sounds like a great piece of kit, however you obviously pay a premium for it.
At the opposite end of the spectrum I've had a quote through BOXT for a Worcester Greenstar 30i which also includes a 10yr guarantee and a Honeywell smart thermostat. On the face of this boiler looks adequate but does have mixed reviews. The quote also includes the system flush, Filters etc, so looks a very good price
Where I'm struggling is the price difference, £700 between the two including fitting and all 'extras'. Is there ATAG worth it? or should I save my money and go for the Greenstar?
there shouldnt be that much between them as there price installer wise the same
any addition kit?
will need a system flush what ever you choose
Have they both been to survey and quote?
Not an online 'from' price?
ATAG quote has been out to survey
The Worcester Greenstar quote is an online quote, however I have spoken to the company on the phone about re-positioning the flue exit slightly (which needs to be done as it's less than 300mm from the floor) and they have confirmed this would be included within the price, including filling of previous hole
Both prices include Flue Kit, Smart Thermostat, Power Flush, Filters, Chemicals etc
I would go with a good local installer
Atag are good, have a look at the trust pilot reviews
Thanks Scott, I certainly would prefer to deal with someone who I've met face to face and trust to do a good job
Where is the boiler installed?. The Atag IC range is basically an Ariston as they bought out Atag. If you can fit it in the A325ECX is the better boiler as it has water recuperation built in at no extra cost.
Commercial boiler so you require the com qual
The A325ecx is not a commercial boiler. It is a domestic combi boiler sold by Atag commercial.
The domestic division of Atag is owned by Ariston and developed the IC range. They kept the original range under the commercial badge.
Deeming it commercial as its under there commercial boiler section
Anything listed as commercial needs a comment engy
Reply to Help!! Another New Boiler Question to replace an old Vokera Syntesi 25 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All, Last night i discovered my Worcester 35CDi II was leaking, I had a new expansion vessel fitted in may as the old one had failed along...
12K
Hello, I hope someone can give me some advice on replacing an old air source heat pump. We moved into a shared ownership house last year which has...
3K
Good afternoon all, Few days ago I woke up and I didn't have warm water nor heating. I did call British Gas straight away and they sent an...
Had three quotes for a new boiler and UV cylinder. All quotes are very similar in price (only about £200 difference between the most expensive and...
Sorry, loads of these questions on here. Getting a new boiler as current 18 year old one is packing up and would like some advice. Opted for one...
5K
