Discuss Heating system keeps losing pressure in the Plumbing Jobs | The Job-board area at PlumbersForums.net
stratplus
Can anyone add to this list of possibilities:
Leak on rads valves etc
Leak on pipework
Leak on air vents manual and auto
Expansion vessel lost charge
Prv passing
Plate hx leaking on primary side
Anything other than the obvious.
If plate hx was mixing with incoming cold the pressure would be higher on gauge and Prv would be constantly passing so no pressure lost .....right?
hex leaking internally and dripping down condense
Interesting, can you explain that one in more detail Shaun please.
To my knowledge the hx has four ports:
Primary F and R
Cold in and hot out
Condense collected from flue gases
How would you lose heating water/mains water through condense?
Ok, you mean main hx not plate.
Still lost though.
Yes main hex
Would be heating water
Main hex could be gone leaking CH contents down the condensate. Is the condensate constantly dripping?
Something I’ve never thought of tbh. Worth a look.
Pressure takes a couple of weeks to resch zero from 1 bar. If the main hx was leaking from internally wouldn’t the pressure drop be much quicker?
Reply to Heating system keeps losing pressure in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have been facing central heating low pressure on unvented hot water RM Cylinders but can't see any leak on the PRV, expansion vessels and plasterboard celling. I have got unvented pressurized RM Cylinders hot water system with 27KW Worchester gas boiler with expansion vessels . When...
losing pressure
L
Hi all not a plumber but am an engineer I have pressure drop in the system Worcester Bosch came back after repressureising the expansion vessel and he replaced the heat exchanger element. The boiler is coming up for 15 years old. The boiler was going below one bar and not increasing when...
Looking for someone that can replace the expansion vessel on an old heating system that is losing pressure every day and needs topping up at least three times a day. Trying to eliminate what the cause could be. Appreciate that it could be a leak somewhere, but looking to tackle one issue at a...
Good afternoon, I am experiencing a pressure issue with my heating system and was hoping to receive additional insight as to what the problem could be. We have a biomass boiler and stratification tank set up and recently had an issue with boiler pressure dropping off when the system was cold...
Can central heating / gas engineer expert help me with below issue. During winter time only, I have been having issue with low pressure or pressure dropping with unvented hot water cylinder system. During summer time there is no usage of central heating so the pressure at unvented system is not...
