Discuss heated towel rails in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
joneff
Hi everyone,
I"m changing my bathroom radiator for a towel rail and it would be easier to couple it up using flexible braided couplings,the type you use for basin and bath taps,is it ok to use these on central heating systems?
the flexi pipes should not be used on the central heating system, if you can not do the job then get a plumber in it will look a lot better if its done right
did you do this saw pictures of it in ciphe mag last month
Reply to heated towel rails in the Plumbing Jobs | The Job-board area at PlumbersForums.net
