Discuss Heat turned off but pump in the airing cupboard keeps running in the Plumbing Jobs | The Job-board area at PlumbersForums.net
B
BlueR32
I turned the heating off at about 10. But the pump in the airing cupboard was still making a noise like it was on.
There's a wall switch which allows it to be switched off in there. So it's off and quiet.
But the manual switch had always been left on before and it was totally quiet unless the water was on heating or the heating was switched on from the control panel in the utility room.
Please comment if you have the solution. Thanks!
What make and model of boiler do you have? Some boilers have a pump overrun which keeps power to the pump for a few minutes after boiler has been switched off.
Also sometimes motorised valves can be faulty and put power to boiler and pump.
You do not show in your photo the motorised valves (for hot water and heating). What type of valves are they, do they have a manual over ride lever, if so work the lever a few times and see if the pump stops when it comes back to the rest position. Depending on whether the last control command was the heating or hot water valve that would be the favourite.
Last time I attended a job with this issue was due to a frost stat in the loft that was faulty causing the pump to run . Check you don't have a frost stat in the loft somewhere , or could be a faulty motor in the motorised valves
Reply to Heat turned off but pump in the airing cupboard keeps running in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi everyone Some very helpful people on this forum (hi John.g) sorted me out with some issues with a faulty installation of a Grundfos UPS3 back...
Where and how does the water supply work and is there only one rising main pipe and where is it usually located? I am top floor flat, mains fed...
Hi I seek some advice on replacing an existing regular boiler. I currently have an old Potterton 10-16 Netaheat electronic, which is around 35...
I have a conventional system, Potterton Prima Boiler, into a Pump into a Motorised Valve that feeds the Radiators and/or the pipes in the Hot...
I just had a quote for a new boiler install as follows I dont undertand why a 15-60 boiler pump is needed and a 25-100 pump is needed as well I...
