Discuss Heat only boiler sizing in the Plumbing Jobs | The Job-board area at PlumbersForums.net
hammers4spanner
Subscribed
Current in situ is an Ideal classic.
Need something sized near as possible to this model due to space.
baxi 400, worcester ri, viessmann 100
what you tight on width?
They have granit stone everywhere and where gas pipe comes out below old boiler it can' be moved.
baxi 400 sizes
Overall Height (Inc Flue) 790mm
Casing Width - 370mm
Casing Depth - 270mm
gas connection right (as you look at boiler)
worcester ri
Overall Height (Inc Flue) 780mm
Casing Width - 390mm
gas connection Left (as you look at boiler)
viessmann 100
Overall Height (Inc Flue) 800mm
Casing Width - 375mm
Casing Depth - 285mm
What about a Vaillant 4 series??
as its you :D
vaillant 400
Overall Height (Inc Flue) 885mm
Casing Width - 440mm
Casing Depth - 316mm
gas connection Right (as you look at boiler)
How about the Ecofit range? . I would check but still working:confused::confused:
eco fit
Overall Height (Inc Flue) 752mm
Casing Depth - 280mm
8.40pm on a friday Harvest not good bud should have your feet up and be on your second pint by now ha ha good luck bud . baxi 400 piece a Sod to fit light as a feather and reasonably priced
what you doing harv
8.40pm on a friday Harvest not good bud should have your feet up and be on your second pint by now ha ha good luck bud . baxi 400 piece a **** to fit light as a feather and reasonably priced
what you doing harv
Talking to a customer about a bathroom I am fitting for them. I then look down and two hours have disappeared. Got one of these now though.
Reply to Heat only boiler sizing in the Plumbing Jobs | The Job-board area at PlumbersForums.net
