- Messages
- 7,712
Current in situ is an Ideal classic.
Need something sized near as possible to this model due to space.
Discuss Heat only boiler sizing in the Plumbing Jobs | The Job-board area at PlumbersForums.net
What about a Vaillant 4 series??
How about the Ecofit range? . I would check but still workingas its you
vaillant 400
Overall Height (Inc Flue) 885mm
Casing Width - 440mm
Casing Depth - 316mm
gas connection Right (as you look at boiler)
I do like the ecofiteco fit
Overall Height (Inc Flue) 752mm
Casing Width - 375mm
Casing Depth - 280mm
8.40pm on a friday Harvest not good bud should have your feet up and be on your second pint by now ha ha good luck bud . baxi 400 piece a **** to fit light as a feather and reasonably priced
Talking to a customer about a bathroom I am fitting for them. I then look down and two hours have disappeared. Got one of these now though.what you doing harv
Reply to Heat only boiler sizing in the Plumbing Jobs | The Job-board area at PlumbersForums.net
