Discuss heat input or output in the Plumbing Jobs | The Job-board area at PlumbersForums.net
when gas rateing an appliance ,modulating burner an old timer told me the final calculated kw outcome should be more in line with the mi heat output not heat input.
yep, input, output would depend on the efficiency, all calcs done on input
Reply to heat input or output in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi apologies of this has been asked before but when you gas rate an appliance and trying to compare to the technical data, do you go off the...
Deleted member 120897
I have a Vaillant boiler and want to set d.0 to something sensible, right now it is set to auto and can range from 6 kW to 37 kW. Adding up my...
2K
A (if) CH system has a very high head loss due to improperly sized pipework and long runs and possibly partially blocked pipes and requires a UPS2...
1K
Hi all, I wanted to ask a general question about an underfloor heating system our plumber is proposing and if this solution will be sufficient...
Hi do we need to do a gas rate or heat input when doing a boiler breakdown? Thanks
