Discuss heat genius/honeywell evohome in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have fitted one to control some rads. Then extended the heating circuit to a ufh manifold. Used the honeywell trv head replacements with the controller.
All linked together nicely and work well.
Fitted loads of Evohome. Not fitted heat genius. What do you need to know??
Do they work with semi gravity system's or does it have to be an s plan or y plan?
Evo home will work fine. You just use the base unit to control TRV heads, then group the TRVs into whatever zines you want.
Reply to heat genius/honeywell evohome in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, My current hot water system needs to be replaced. Anyone got any suggestions or can recommend any plumbers around Derrimut area that won't...
Hi guys. I'm trying to identify a toilet model before ordering a seat for a customer. I went to what used to be a Roca stockist (they no longer...
I have an ideal vogue max S18 boiler and I’m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler...
