Discuss heat genius/honeywell evohome in the Plumbing Jobs | The Job-board area at PlumbersForums.net
TFGplumbing
Hiya guys any one fitted either of these control systems?
I have fitted one to control some rads. Then extended the heating circuit to a ufh manifold. Used the honeywell trv head replacements with the controller.
All linked together nicely and work well.
Fitted loads of Evohome. Not fitted heat genius. What do you need to know??
Do they work with semi gravity system's or does it have to be an s plan or y plan?
Evo home will work fine. You just use the base unit to control TRV heads, then group the TRVs into whatever zines you want.
Reply to heat genius/honeywell evohome in the Plumbing Jobs | The Job-board area at PlumbersForums.net
