Discuss Heat Bank in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Matt06
Hello
Never fitted a Heat Bank before but customer wants one, Personally i don't see the point as they are only have a gas boiler as heat source
Usually i would just install a decent unvented cylinder and a system boiler
the one they are looking at is Xcel DS 300 3 from Specflue
Does anyone know if they are any good? Should i try and push them towards an Unvented system? though i think they already been convinced to install the heatbank system
I can see the benefit of installing one if they had biomass/solar etc but for a Gas boiler i don't see the point
Any Advice Appreciated
Hello Matt
I think you know the answer to this one! Heat Banks are great when using two or more heat sources. When using a modulating gas boiler with thermostatic control I can see little point going to the expense of installing it. It is quite a bit more expensive to purchase compared to say a 250L unvented cylinder and more expensive to fit. Are they planning to have another heat source added to the heat bank?
Providing there is adequate pressure and flow, an unvented cylinder would seem the better option.
Cheers
John
Reply to Heat Bank in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have been facing central heating low pressure on unvented hot water RM Cylinders but can't see any leak on the PRV, expansion vessels and plasterboard celling. I have got unvented pressurized RM Cylinders hot water system with 27KW Worchester gas boiler with expansion vessels . When...
losing pressure
L
Can central heating / gas engineer expert help me with below issue. During winter time only, I have been having issue with low pressure or pressure dropping with unvented hot water cylinder system. During summer time there is no usage of central heating so the pressure at unvented system is not...
I just had a quote for a new boiler install as follows I dont undertand why a 15-60 boiler pump is needed and a 25-100 pump is needed as well I currently have an ideal mexico 2 heat only boiler - It has one DAB pump on the boiler return and a 2 port valve at the flow pipe to allow for heating...
T
Hi We urgently need to get our h/w cylinder replaced because it's leaking. Our current system is oil boiler feeding underfloor downstairs, radiators upstairs and an unvented hot water cylinder for hot water. We are thinking of moving to a heat pump at some point but aren't ready to do this. My...
Afternoon all, I have a customer with a heavily extended semi which now has 4 beds, 2 bathroom and 5 reception rooms. They have started working from home and want to zone the heating system, unfortunately the system boiler and cylinder is in the garage with 2 x 22mm primary pipes disappearing...
