- Messages
- 1,279
hope you can see the pictures, anyway, i went to a job today to work on a glowworm boiler, i found a hole that is on the plastic manifold between the heat exchanger and the condence trap, it looks as if it has melted but hard to tell, the picture shows the black plastic piece that is screwed to the bottom of the heat exchanger (this is the bit that is leaking). I will ring glowworm tomorrow to discuss but just wondered if anyone else has seen this before? knowing manufacturers like to rob you blind i imagine they will tell me this piece doesn't come seperate to the main heat exchanger. Thanks !
