Discuss Hansgrohe I box bath/shower mixer in the Plumbing Jobs | The Job-board area at PlumbersForums.net
scrivtech
Fitting one these and need help!! There's reducers to be made in then do I use male irons? Also tappings for 22 and it's 15 from combi do I take 22 to bath. 15 into to mixer work? Thanks
Yes mate screw those bushes in and a male iron into them to accept the 15mm pipework, great shower choice!
as said above, 15mm feeds for hot and cold then 22mm male iron and take 22mm to the bath then 15mm to the wall outlet. refrain from using compression joints behind the wall if you can help if for the wall outlet. i like to always use soldered wingbacks then you know theres no chance of it moving/loosening the compression joints when you screw the wall outlet in (ive seen this happen on numerous occasions) but its a very good quality shower choice
Reply to Hansgrohe I box bath/shower mixer in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Just started gound work on self build bungalow and wondering best way to do below ground soil pipes. For toilet I was going to go straight down...
