Discuss Gurgling and air in central heating in the Central Heating Forum area at PlumbersForums.net
@johntheo while I was looking I noticed this.
Also some of the copper pipes into the boiler have this.
Anything to worry about?
Will see if there are isolating valves behind.
The pressure only drops/rises when the pump goes on/off. Not during heating.
Haven’t checked when using hot water but will check tomorrow.
That is the filling loop with a non return valve where shown and a isolating valve where shown on the other end, ensure the isolation valve is closed "across (at right angles to) the pipe" then just slacken the flexible hose where attached to the NR valve but do not remove it, when slackened a few turns water should only dribble out for a few seconds and then stop.
There may be another isolation valve on top of the NR valve but I don't think so, if there is, shut it as well
Ok, I’ll try this tomorrow along with the hydrogen check!
Do you think air could be somehow being pulled into the system here?
If so, would it be the loop or the NRV?
No, I think it highly unlikely because even if the flexible hose is perished/holed then with a sealed system the pressure should still keep the NR valve shut. I also find it difficult to imagine that you are pulling in air anywhere in the volumes that you are getting especially if the boiler pressure is normally 1bar or higher. Lets hope in one way that its hydrogen!.
I’ll take a video of the amount of air/hydrogen coming out so it’s easier to see.
Is it worth doing the bleed when the system is cold? And by cold, how long should the system be off for?
I've only had to vent some air from my open vented system after a complete drain down and refill, I would stop the circ pump/boiler and then vent when hot. Hot or/& cold better IMO to vent with pump off.
I vented the bathroom towel rail today. Heating was turned off. System was still a bit warm.
I got about 7 seconds worth of air with a quarter turn of the bleed valve.
Here is the pressure before bleeding:
And pressure after bleeding:
Thing is, the pressure gauge usually varies a bit.
From earlier in the week:
@jim843 I tried the hydrogen test. There was no pop.
@John.g do you still think it's worth removing the filling loop?
@johntheo I turned on the hot water and the pressure does drop. It went from about 2.4 to about 2. Is this a problem?
Thank you all for your help. It's been very useful for me to vent (no pun intended?!) and discuss this.
Yes, definitely remove (after first slackening) that filling loop, it's only hand tightened at the connection to the NRV, obviously ensure that the isolaton valve is shut, as it appears to be, then post back.
Ok. Just so I'm clear, remove loop and leave it a couple days and see if there's any air in the system?
Reply to Gurgling and air in central heating in the Central Heating Forum area at PlumbersForums.net
When I turn on our CH there's a lot of noise from one specific part of the system - the pipes on the landing, and one radiator. It sounds like...
PSxxxxxx
Boiler is making a gurgling sound and keeps short cycling. I believe there is air in the the system and I've already bled all the radiators. This...
losing pressure
L
I need to extend my central heating from my newly built extension in to the old part of my house. I need to feed 3 rads in separate bedrooms on...
