Discuss GSR Inspection in the Plumbing Jobs | The Job-board area at PlumbersForums.net
jaydebruyne
So, did my first gas job under my own number yesterday.. boiler install.
Got notified this morning my inspection is in Feb.
Any advice? My anxiety is through the roof already!!!
Did the install by the book, commissioned by the book. (As always!).
Just want a heads up on what to expect.
Cheers
Jay
Make sure all your paperwork, labels, flue Anylyser calibration certificate is all available and in good order when they turn up and then just try and chill. Most of them are decent folk and will generally ask you basic questions about purge volumes, gas rating, tightness testing etc which you do all day anyway and in my case always allow for some tongue tied Swahili which generally will come out of your mouth if nervous.
Paperwork
Have your book
Calibrated FGA
Be polite
Listen
Ask if they're happy with apps for valve don't assume
They are not there to catch you out they are decent guys and are there to help you
Hmmm, I my boss has the fga cert - will have to sort that.
Only labels I have is the standard new AR/ID label, what others do I need?
I've started another thread re: paperwork. Re: boiler installs, apart from CP12's, commissioning record and notifying the work with gsr there isn't any other paperwork I need to do is there?
They are the main ones but any that you use in everyday use- mine mentioned how many people don't have them
You will be fine just take your time and go through it with him
Mines was
Gas rate
Tightness test
Gas pipe vis
Flue and clipping
Fga readings
And a chat about him :D
Mines was
Gas rate
Tightness test
Gas pipe vis
Flue and clipping
Fga readings
Thing is when I get nervous my brain just shuts down and refuses to cooperate!! I just hope I don't mess things up..
Gonna brush up and read my viper book and prepare..
Cheers Shaun
Cheers Shaun
They understand this if it helps just imagine your talking to one of us
Most inspectors are ex Engineers, a lot are fro BG.
They have been in your shoes and as above, there are not there to catch you out at all.
I've met a few over the years and they're always friendly and helpful.
Don't worry about it.
Trust me, I'm a plumber
What happens if they ask something and you get it wrong?
you'll be fine I ended up capping a boiler once on my first probation visit due to a low service pressure he was just pleased I knew what to do
Oh ok.. slightly less pressure then :)
as long as you dont kill him or leave your cus with an open end / try and kill them you will be fine
Relax for now and prepare yourself.
When you meet the inspector and he/she asked how you are....tell them, this is your first inspection and you're about to pee your pants.
At least that way, they know you are on edge and some of your replies may seem out of context or complete jibberish, but they will understand the situation.
Everyone's been there.
Cheers everyone.. think I'll re-read this thread every day to try and ease my pain lol
What fga do you use?
My kane tells me the recalibration date when i turn it on
If you dont know something just tell them you dont know but you can look it up for them.
Thats all they want. No bullshyte. They dont expect you to know everything.
aye
don't forget you can always look in the book when your stuck i did for some ventilation questions on mine.
there pretty easy going guys and not there to catch you out.
they also realise you will be nervous and account for it.
Mine asked me something like "are you sure about that? Think about it for a minute.." I still couldn't remember the right answer so I said I had Viper in the van and could have a look... He was fine with that.. Something to do with compartment ventilation if I remember right...
I'm sure I'll be a bit more confidant when I go through my Viper ... *he says*
If an existing installation of a hob does not have an isolation valve, would this be classed as NCS or AR? The ECV at the meter is accessible within the flat about 10 feet away from the hob.
Reply to GSR Inspection in the Plumbing Jobs | The Job-board area at PlumbersForums.net
