Discuss grundfos UPS 3 phase pump in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Mis-read the pump type, thought it was a 65-80, which i do come across on domestic premises, and in my opinion do not last that long, and are expensive.
Just as well i didnt start giving him electrical advise over the intenet, he might get himself a shock.
That is what forums are about is it not giving advice
experience is gained not learn t by reading internet posts
Hi presuming you know how to use a multi meter.
First make sure it is electrically isolated the disconnect the 3 phase conductors.
then using you multi meter on the ohms setting test between Phases 1+2 then 1+3 then 2+3 the reading should be very similar give or take 1-2 ohms
if this is not the case then check for voltage after you have re-connected the conductors i.e. 440 between phases and 230 between each phase and earth
thanx for the info mate, its all sorted now
did test ech phase and found 2 of the 3 phases were down. The mcb were wired into somekind of protector and 2 lights on the front of them were red, 1 was green. this was replaced and hey presto, all working again. thanx again mate
Reply to grundfos UPS 3 phase pump in the Plumbing Jobs | The Job-board area at PlumbersForums.net
G
  • Locked
Hey, To cut a long story short I decided as a single mother that I would google and work out how to get air build up out of my heating system...
12K
  • Locked
Morning guys I installed a new Grant 26e external combi just after Christmas. The oil supply was on a temporary supply from an ivt tank which was...
4K
M
  • Locked
Hi I'm doing up a house at the moment, its a repossession thats stood empty for 10 months. The Grundfos circulating pump next to the hot water...
downthesouth
M
  • Locked
Hi Guys First post and a long story so bear with me please. Have been on several other forums and had a load of help on various things but my...
A
  • Locked
Evening all. I'm a regular user of the tiling forum but have popped over here to see if someone can help me work out what the problem is with my...
7K
