Discuss grundfos UPS 3 phase pump in the Plumbing Jobs | The Job-board area at PlumbersForums.net
B
beesley121
Hi guys,
does anyone know how i can test wether this pump is working or not?? i have a pump and im sure its not working as i cant feel it rotating. Ive opened up the bleed screw and it only dripped a little then stopped. I even took it completely out and would have thought water would have gushed out when the water in under 1.5 bar of pressure but it didnt. hardly got a drop
could it just be the terminal box with the speed controller in thats gone?? how do i test this?? or is it the motor its self?? how do i test this??
lso guys, should i need new motor, does the terminal box come with it?? or can you buy the terminl box seperate as im thing it may be just the terminal box and its workings that have gone.
any help appreciated guys
did you turn the gate valves off,please elaborate
I'm as confused as gas man and would also like to help.
Where is the pump, is it inside the boiler or airing cupboard?
Have you taken the head off or completely removed the pump?
And as gas man asked, have you touched the isolation valves?
hi, thanx for the replies guys.
the gate valves have not been touched. this is a commerical pump. the problem we are having is that we seem to be only getting CH hot water on one side of the rads so its as if the rads are not returning to the boiler. the pump is a grundfos ups 65-180
if theres no water in there you either have a tank thats run dry,or a valve off some where
I would like to assume that you competent to work in commercial premises
On 3 Phase equipment exceeding 400v >?
are you talking to me or the op?i did not post that,asking the op a question
Ive seen those pumps in domestic premises, I know they dont last very long.
I would get a professional in, if the pump does need changing is not gonna be a cheap job anyway.
Reply to grundfos UPS 3 phase pump in the Plumbing Jobs | The Job-board area at PlumbersForums.net
G
  • Locked
Hey, To cut a long story short I decided as a single mother that I would google and work out how to get air build up out of my heating system...
12K
  • Locked
Morning guys I installed a new Grant 26e external combi just after Christmas. The oil supply was on a temporary supply from an ivt tank which was...
4K
M
  • Locked
Hi I'm doing up a house at the moment, its a repossession thats stood empty for 10 months. The Grundfos circulating pump next to the hot water...
downthesouth
M
  • Locked
Hi Guys First post and a long story so bear with me please. Have been on several other forums and had a load of help on various things but my...
A
  • Locked
Evening all. I'm a regular user of the tiling forum but have popped over here to see if someone can help me work out what the problem is with my...
7K
