Discuss Grohtherm Wireless Digital Pumped Shower - Replaced by Grohe F-Digital - Faults! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
T
tcimino
Hi, first post so hoping for some help...
I had a Grohetherm Wireless Pumped shower that was constantly dripping so Grohe recently replaced it with their latest version - Grohe F-Digital. Problem is that it keeps cutting out after about a minute or two. The trigger seems to be when you dial up the demand for hot water on the controller. It just runs dry then cuts out.
I've cleared all the usual issues: Hot water supply from the hot water cylinder is froma non-vented surrey flange connected. Pipework from cylinder to shower is all brand new and cleared/check for blockages. Hot water temperature is fine - below 60 degrees C.
Anyone out there have any bright ideas??
Thanks!
Not being funny but if grohe fitted it, get them back.
I'm pre-empting th e inevitable response that it's 'not our issue.'
I know I'm new here, but if your suggestions are flippant, keep them to yourselves please.
Thanks.
There was nothing flippant in that response. You're the one being rude.
In light of your request all suggestions will be kept to ourselves.
Thread closed.
Reply to Grohtherm Wireless Digital Pumped Shower - Replaced by Grohe F-Digital - Faults! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello I need to replace my Grohe Geotherm shower cubicle mounted control unit. Its around 17 years old but replacements seem to be available The...
Hi all, Got a nightmare situation with a central heating system I recently adopted. It's an open vent system with a combined F&E pipe, with a...
2K
Firstly , apologies if this is inappropriate. I'm really not sure what questions I should be asking. I had a bathroom refit done around 7.5...
2K
Hi. I'm currently estimating on installing a new shower pump to feed an existing bath/shower diverter. Hot side: fit flange and spherical valve...
5K
The Mrs bought me a digital shower (Mira Platinum- Gravity Fed) for my birthday. Obviously it was for her really...
2K
