Discuss greenstar 24ri banging noise on shutdown in the Plumbing Jobs | The Job-board area at PlumbersForums.net
p nelson
My 24ri boiler is four years old and has started making loud clicks and banging noises when shutting down.
This after it was off for six months due to house rewiring and relocation of header tank.
It does not happen every time it shuts down and was serviced by plumber in September.
Hard to say what that is without seeing and hearing it , maybe get your gas engineer back to have a look at it.
Reply to greenstar 24ri banging noise on shutdown in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Desperate for some help! Be a life saver of someone can help as suffer from a high intolerance to noise. Moved into new house 1940s (copper pipes) and having serious issues with banging pipes only when central heating is on. Not when running taps We have a wall in living room that has stop tap...
T
Hello, I have just moved in to a new flat this week and have a problem with noise coming from somewhere around the top of the boiler. It's a loud clicking/knocking sound that lasts about a minute, stops for 20-30 seconds and starts again. It seems to happen at night, starting in the evening...
Hello, purchased a house in February this year and for a few weeks, noticed a loud banging noise which sounds like it is coming from under my sink, but happens when no water is running. I think it could be when my neighbour is either running water or maybe using a washing machine. House is an...
Hi there, My boiler (Worcester Greenstar Ri) has started making a soft knocking noise when it turns on, and again a few times when it turns off. I've attached a short video of the sound. It isn't constant, it seems to happen within the first 10 mins of the boiler starting up, then you won't...
My radiators make a bang noise every now and then. Doesn't seem to be a particular radiator instead it will be 1 radiator and then some time later another radiator and then some time later another. Only 1 at a time I think. At least I think this is what's going on. By way of background; I have...
