Discuss Grant flue seals in the Plumbing Jobs | The Job-board area at PlumbersForums.net
PhoenixServices
Guys where is the best place to get grant flue seals from. Can't find anything online.
HWOS or a call to Grant technical and get some sent direct...
Reply to Grant flue seals in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi Oil experts. I had a grant wall boiler with a failed transformer. Carried out a service and pretty sooty nozzle, and baffles build up suggest not cleaned in a while. The bottom baffle on the left corner had completely burnet through. Any Idea on the process on how this occurs and why just...
Grant Vortex 50/90 condensing oil boiler where the air tube spigot over the fan is not connected to the existing flue, should this be closed off with a Reillo cover plate to stop vermin getting into the open fan motor.If is blanked over will need a further combustion test to confirm adequate...
Oily smell from boiler recently before failed. Great plumber sorted though when opened external baffle at front of sealed flue the internal spring like tube lining outer insulation had all perished. Barn conversion with thick walls (763mm). Worcester Bosch say Flue Kits are obsolete and...
Hi all Plumber who fitted shower frame didnt put sealent behind frame to tray before fitting frame. Now leaks when water gets into frame and down into downstairs wall Another plumber has sealed inside area whwre it is shown yellow , which i get is not ideal. i was going to just seal a thin...
My Grant combi oil boiler is giving me quite a headache at the moment. When I returned home last Friday I'd no heating or hot water. An engineer called the next day and diagnosed a faulty pressure switch. This was changed and everything seemed ok. However then the boiler began to lose pressure...
