Discuss Grant combi CHP not running in the DIY Plumbing Forum area at PlumbersForums.net
I
IrishTaff
Grant combi boiler, Light on CHP not on and no electrical supply to pump, programmer switch set to constant. DHW pump light on and running but programmer switch is off. Check one way valve on CHP seems to be free and working.
Which model Grant combi there are several.
CH will not work if there is a DHW demand which DHW pump running suggest there is .
If you have a multimeter and are competent to use it check if there is a live feed back from flow switch.
Reply to Grant combi CHP not running in the DIY Plumbing Forum area at PlumbersForums.net
Hi, I have an issue with my Grant Vortex internal combi boiler. Specifically the electrical side. Everything was working fine (with a dual...
My Grant combi oil boiler is giving me quite a headache at the moment. When I returned home last Friday I'd no heating or hot water. An engineer...
Hello, my Mothers heating failed in the recent UK cold snap. I found the pump was stuck. I have a question about pump orientation. The...
My son has just had a new boiler fitted and hes noticed that the pump runs 24x7 even when both the heating and hot water are set to off. He’s...
My central heating is run off a heat pump ( air to water ) quite expensive to run , So I’m plainning to fit a wood burning with a back boiler to...
