Discuss Good Afternoon, some advice on waste fittings would be much appreciated. in the USA area at PlumbersForums.net
Good Afternoon,
As you may guess in the following message, I am by no means a plumber.
My colleague has specifically requested a solvent version of a 110mm 135 Degree waste union to finish a part of a project. I have been having difficulties finding it though. I have found this type of unit that has one side that is more like a compression fitting with a rubber ring but he refused. I wondered mainly about the difference if any, between the two, and what the overall benefits are for each.
I have done some amount of limited research but wanted to hear it from a professional. Personally, I do not see an issue with using the fitting with a rubber flange, they are designed for something right? that's my logic at least. Am I wrong?
Thank you in advance.
Regards
Rhys
Best to let him get what he wants
I think you just mean a 45deg coupler.
Called 135 by some.
These are available in solvent weld as double socket or socket/spigot. You just need to go to a proper plumber’s merchant - not a diy place.
We call it a 45, ‘cos that’s how much it throws you off from a straight line.
Called 135 by some.
Ah, of course, that makes sense.
I have found a company that can provide what he has requested.
Thank you all for your help.
Reply to Good Afternoon, some advice on waste fittings would be much appreciated. in the USA area at PlumbersForums.net
Hi All I found this forum quite by chance this afternoon whilst looking for an answer to a plumbing question that I have following a rebuild of...
Hi everyone, First a quick bit of background : I'm English, living in France, and renovating a 1960s house, which has pretty much needed to be...
2K
Hi All I am looking to fit a 600mm dishwasher, i will be fitting it under counter in a current 600mm 3 drawer carcass (i presume this is ok once...
2K
Hoping for some advice on the use of AAVs while plumbing in my new bathroom. There is a sketch of the waste layout in the link below. All of the...
2K
Stephen44uk
I am really struggling with how to do the waste pipework from a shower tray and would appreciate any advice on the best approach to take. The...
2K
Deleted member 120897
