Discuss Good Afternoon, some advice on waste fittings would be much appreciated. in the USA area at PlumbersForums.net
Good Afternoon,
As you may guess in the following message, I am by no means a plumber.
My colleague has specifically requested a solvent version of a 110mm 135 Degree waste union to finish a part of a project. I have been having difficulties finding it though. I have found this type of unit that has one side that is more like a compression fitting with a rubber ring but he refused. I wondered mainly about the difference if any, between the two, and what the overall benefits are for each.
I have done some amount of limited research but wanted to hear it from a professional. Personally, I do not see an issue with using the fitting with a rubber flange, they are designed for something right? that's my logic at least. Am I wrong?
Thank you in advance.
Regards
Rhys
Best to let him get what he wants
I think you just mean a 45deg coupler.
Called 135 by some.
These are available in solvent weld as double socket or socket/spigot. You just need to go to a proper plumber’s merchant - not a diy place.
We call it a 45, ‘cos that’s how much it throws you off from a straight line.
Called 135 by some.
Ah, of course, that makes sense.
I have found a company that can provide what he has requested.
Thank you all for your help.
Reply to Good Afternoon, some advice on waste fittings would be much appreciated. in the USA area at PlumbersForums.net
