Discuss Gledhill Pulsacoil A Class???? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Riley
Super Moderator
S. Mod
Subscribed
Anyone got experience with these thermal stores?
got one that is barely producing any hot water I have zero experience does anyone have any pointers please?
cheers
Is the store itself hot but cold water at the taps , check blending valve .
Check little f&e has water in it .
Main thing on these
is immersion heater stat is goosed
Thanks guys
Problem appears to be good hot water for maybe half a baths worth
Then stone cold and doesn't heat up again till next off peak.
As I say my understanding of these is limited but from reading the literature they are supposed to be similar to a Combi with instantaneous hot water. Are the tenants expecting too much?
it sounds like its just not getting to temp mate , try a stat , they use cotherm stats (or did do ) not the best IMO
Thanks fella I'll have a look
It's expensive but their technical is pretty good, and there's normally a couple of dip switches to press on the pcb which then gives u temperatures etc.
Reply to Gledhill Pulsacoil A Class???? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, My current hot water system needs to be replaced. Anyone got any suggestions or can recommend any plumbers around Derrimut area that won't...
Hi All, does anyone know why the water only fills 1/3 of the way please?
Has anyone one fit or serviced one of these before; Heatrae Sadia 25l 9004010. It a 25 litre hot water storage cylinder.
