Discuss Gerbrit concealed syphon in the Plumbing Jobs | The Job-board area at PlumbersForums.net
hammers4spanner
Subscribed
Got one of these that needs replacing its gerbrit but not sure what the name or code is for it anyone know??
Is it passing water ? totally knackered?
Is the washer on the base blistered?
Looks like it in the photo
Just needs the seal replacing if it that... Popping them with a pin is a short term fix till you come back
Rather replace than repair not into short term fixes as its still a charge that if i was a customer wouldn't want to incur.
If you can repair it and you are certain it will work without having issues in the next weeks / month np than its nothing wrong with that.
As long as the mechanism works and you are able to change the seal / washer you are good to go.
But you are quite right it's always better to replace parts
I recall changing a grohe washer once & had multiple call backs about it not shutting off, I did indeed end up changing the whole lot lol so know what you mean!
Reply to Gerbrit concealed syphon in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Did anyone watch Britain's Got Talent last night? There was a Plumber on from Stockport called Darren who bottled it last year but did his audition last night.. He was a stand up comedian and he got off to a rocky start but by the end everyone was loving him! Does anyone know him? Is he a...
Can anyone recommend a decent multi meter, preferably under a 100 pounds. It's for checking boiler components so I don't need a top spec one ....just easy to use and reliable. The fluke 115 looks good but its above my budget. My current socket and see one was great but it's developed a fault.
Does anyone know where I can get one of these? Toilet is leaking into the bowl. This one pushes in with a half turn but I can't find one anywhere.
