Discuss Gerbrit concealed syphon in the Plumbing Jobs | The Job-board area at PlumbersForums.net
hammers4spanner
Subscribed
Got one of these that needs replacing its gerbrit but not sure what the name or code is for it anyone know??
Is it passing water ? totally knackered?
Is the washer on the base blistered?
Looks like it in the photo
Just needs the seal replacing if it that... Popping them with a pin is a short term fix till you come back
Rather replace than repair not into short term fixes as its still a charge that if i was a customer wouldn't want to incur.
If you can repair it and you are certain it will work without having issues in the next weeks / month np than its nothing wrong with that.
As long as the mechanism works and you are able to change the seal / washer you are good to go.
But you are quite right it's always better to replace parts
I recall changing a grohe washer once & had multiple call backs about it not shutting off, I did indeed end up changing the whole lot lol so know what you mean!
Reply to Gerbrit concealed syphon in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Sticky
IS IT POSSIBLE TO ADJUST THIS MIXER UNIT? WE HAVE TO HAVE IT TURNED ALMOST FULLY ANTI CLOCKWISE TO GET HOT WATEROUT. THE FRONT PLATE WITH MIRA ON IT PRISES OFF AND INSIDE THERE ARE SOME PLASTIC BITS AND A SMALL CROSS-HEAD SCREW IN THE MIDDLE. THANKS
