Discuss Gas Rating in the Plumbing Jobs | The Job-board area at PlumbersForums.net
F
Fowlersrs
Alright guys, quick question..
Is gas rating nat gas boilers and appliances still necessary if carrying out flue gas analysis?
Reason I ask is because ive spent the last 3 years only working with LPG appliances and obviously you cannot gas rate them as there is no meter with LPG.
So is it still necessary with nat gas, ive just started my own business and im doing alot of nat gas services and I am carrying them out at the moment in conjunction with my fga but it does seem a little pointless. Ive got my gas safe inspection in a few weeks so dont wanna drop a bollock if there gonna be expecting me to do that aswell..
I tend to do them as matter of fact whilst servicing. Feel it's a bit OTT on a llgsc unless I can see something obviously wrong with the pipework or the flame
Yes, you need to. Either burner pressure or gas rate on every appliance. Combustion analysis can be fine, but the gas rate well off. Need to do both.
As above.
The appliance is rated to consume a set figure of gas. This has to be checked, either by gas rating or BP. If this is way off it may be as a result of some issues within appliance.
The combustion readings may not show anything untowards.
I draw your attention to GSIUR 26(9)!
Gas rate every time , better safe than sorry and only takes a few minutes for peace of mind.
problem is not all boilers have a chimney sweep/max rate mode. dont know about you guys but i find that frustrating because even running the hot tap full blast those boilers will sometimes modulate down
on this subject, how many of you guys test the inlet pressure on the gas valve to see its getting enough gas, easy thing to do, but often overlooked on CP12s
Reply to Gas Rating in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
Hi all, I am a plumber but I do not carry out works to boilers as the majority of my is bathrooms so I am not gas safe. I have completed a...
    • Informative
Why am I not surprised? Britain’s gas network still using engines from 1960s RAF fighter jets Ageing aircraft turbines will cost millions to...
Hoping someone can give me advice with this one. At an annual gas service today I found a Worcester Greenstar Junior 28i to be using only running...
2K
Hi All My husband and I are re looking at the finances for the business and I wanted to ensure the company still remains competitive with prices...
2K
Good'ay Wondering what I have been doing wrong or what I should be doing differently. Have had some jobs lately where I will carry out a gas...
