Discuss Fully pumped system in the Plumbing Jobs | The Job-board area at PlumbersForums.net
H
hessyboy
What boiler would anyone recommend to replace?. Its on a y plan 3 bed semi 8 rads and 1 bathroom. Cheers
intergas combi size dependant on flow rate custard happy with
New solo
Reply to Fully pumped system in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello, my Mothers heating failed in the recent UK cold snap. I found the pump was stuck. I have a question about pump orientation. The...
Central Heating Pump - G Pump Force HE-RS25/6PWM-130 Hi, I would be grateful if someone could explain whether our CH system can cope with the...
Hi, I have just had my central heating system "upgraded" for a four bed-roomed detached house. The heating company recommended going from the open...
1K
AFAIK the boiler is set to fully pumped. (The switch inside is on fully pumped), however the pump is only running while the boiler burner is...
