Discuss fsd on cooker burners in the Plumbing Jobs | The Job-board area at PlumbersForums.net
billybob150811
I always thought this applied to multi occupancy dwellings but on a gb-gas video it says flats which are a single family unit what is correct i dont ncs a cooker in a flat if it doesnt have fsd on burners but now im not sure
if the flat is rented and cooker/hob already there its ncs. If the flat is owned not an issue as far as I understood, after all what owner ever has a cooker serviced ? :)
Read Technical Bulletin 015 (on page 9 on gas safe TB site)
All the answers here.
Also, applies to rented or owned, no difference.
Reply to fsd on cooker burners in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi there, Big gas noob here. We got a gas cooker installed a few days ago, and the gas cooker is now sitting quite far away from the wall (3cm...
Im fitting a kitchen in my own house . When removing the gas oven on a bayonet fitting and turned the gas hob off and removed a four burner gas...
Hi, Wanted to clarify something in regards gas cookers in rental properties. Have a landlord who wants to rent out his house to a family however...
6K
Equipment The shower (a cold feed electric unit) and the Kingspan tank are on the top floor of a 3 storey building. The Ideal Boiler Logic Heat 15...
M
Hi I live in elderly sheltered property and have nothing but trouble with thermostat. I’m a bit confused. When i put it on 19 degrees intuitively...
