Discuss Franke Olympu Kitchen Mixer Tap washer and O ring replacement. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I bravely decided to replace the washers and O ring myself after the tap leaking for ages at the bit that swivels. I removed the grub screw at the back but then had to get a friend to pull the curved part out as it was stuck. I replaced the two washers and the o ring but I now can't get the top of the tap back in the hole. This should be so simple! Any advice would be gratefully received.
As KOPs post - and also recommend you use some non toxic silicone grease (or a little Vaseline if you don’t have silicone grease)
Had to edit post as Riley beat me in mentioning silicone grease. :)
washing ip liquid works also
Well, despite all the advice, I'm beaten. I've tried the lubrication and have tried to find a groove to locate it in the right position but it just goes in by a few millimetres and stops dead. I'll have to 'get a man in' after all. Thanks though x
Hope you were supplied with correct O rings? If they are too tight, then no chance of shoving it in.
The grooves also must be totally clean - (no remains of old O rings etc.)
Have to say that's my suspicion too!
Clare, where did you get the o-rings?
Oh, please do not use petroleum jelly to lube nor washing up liquid. Both will harm the o-rings by causing the rubber to break down.
I ordered the bits and bobs on the Internet and assume they are the right ones. They came in a little kit for that tap but perhaps I'm being optimistic!
Reply to Franke Olympu Kitchen Mixer Tap washer and O ring replacement. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
