Discuss Flow and return temperature in the Plumbing Jobs | The Job-board area at PlumbersForums.net
bassmonster
Hello all,
Is there and ideal temperature that shout be set for dhw and heating?
If its too cold turn it up
If its too hot turn it down
Somewhere in the middle of those two is ideal :beer:
63c or below if you've got a lot of DHW storage - typically will heat to 57ish. But if it's high use temp needs to be higher to keep up with demand. But blast it once a week to keep Liggonella at bay.
Thanks for the reply guys. Reason why I was asking is because my friend called me up saying that she has scalded her hands as the boiler British gas fitted was making the water too hot. 2 engineers came round but couldn't figure out what the problem was. I then asked her to check the temp which was set to 75c. I told her to turn it down to 55c. I'm just a bit puzzled as to why those engineers didn't just turn down the temp.....
What is ufh?
What is ufh?
Under Floor Heating
Water at hot outlets should ideally be maximum 48C and for vulnerable people, 38C (I think)
Flow temp of primary should be set such that return is well under 55C for condensing, whilst maintaining a 20C delta between flow and return.
What is ufh?
HSE guidelines state stored domestic hot water temp should be at a minimum of 60°C (typically 65°C) to prevent onslaught of Legionella.
Advise on fitting thermostatic mixer valves at taps if temperature is an issue.
Looked at the picture. Is there a cylinder stat fitted?
If not have one fitted!
Temps from memory:
Flow 82 Return 72 (non condensing)
Cylinder (DHW) 60 (stat fitted 1/3 up from cyl base)
Reply to Flow and return temperature in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have an ideal vogue max S18 boiler and I’m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler...
Sonya K
Hello to everyone.Im a newbie here. plumbing & heating+GSR engineer.
