Discuss Fixings for dot & dab ( dry lined ) walls in the Plumbing Jobs | The Job-board area at PlumbersForums.net
BN9Pete
I have a job coming up where I have got to install 2 upright rads to dot & dab/ dry lined walls.
I am looking for advice on which is the best type of fixing for this job, I have installed a few upright rads but always on brick or block walls.
I have seen a product online called Dryline Pro which is designed for these walls, but I haven't seen them sold in any builders/plumbers merchants or in Screwfix. Don't really want to order them if I can buy something locally to do the job.
The rads are single panel and 2 metres high.
Thanks in advance, as I won't be back online until this evening.
If you ever get stuck in the middle of no-where and don't have fixings for dot and dab, we used to:
1. Measure the distance between the wall and the surface of the plasterboard (stick a screwdriver through where you want to drill and, measure it).
2. Cut a piece of copper to this length to act as a sleeve for the screw and for the surface appliance / rad bracket to pull up against.
3. Drill your hole into the brickwork as normal and fit the appropriate wall plug.
4. Put a decent washer behind the screw to give it added support.
5. Fit the appliance / rad as normal.
This was the old method of fixing to dot and dab before all the nice fixings supplied nowadays and it does work nicely so just ensure you have a few decent washer just in case the expensive fixings run out!
4" x 12 screws if there is no dab near by then some expanding foam between board and wall can stop board movement.
just done 14 rads couple of weeks ago, bloody nightmare 2'' void behind wobbly 9mm plasterboard!
ended up using my last supply of 100mm x 14's pozi's then no-nailed the bracket to plaster board.
going to try those brown grip-its next time with some no nails to glue them in.
Reply to Fixings for dot & dab ( dry lined ) walls in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello all, I'd like to get some advice on the following issue. We have relatively large tiles (see image 1), and the idea was that the vertical...
Hoping for some advice as I seem to be hitting a brick wall. Moved into a house last year, radiators down strairs (4 of them) never really got...
Hi I need some advice as this has been ongoing since august and nobody can find a problem but meantime water is damaging my walls. The lady...
Hi I have installed my concealed shower valve and fitted wall panels, I'm soon ready to put shower fittings through the panels and screw them into...
2K
Hi everyone. I'm currently working on a job for a customer. their radiators are not all heating up. in total there is 12 radiators. 4 of these are...
