Discuss fitting new pipe and spreaders to vintage urinals - but can't get in behind them! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
T
tapdancer
Hi. I'm fitting new pipe work and spreaders to a vintage type triple urinal. The spreaders that are there look like they are fitted and tightened from the back, although the supply comes down the surface from the top. I can't get in behind them now though. Should be able to get old spreaders off then fill holes and re-enamel whole urinal. Can anyone suggest a spreader that I can fit to the surface.? How would it be fixed etc? I Can clamp the supply pipes down the wall easily but fixing to the urinal is the problem.
are we talking about a slab urinal with seperate heads for each position or seperat urinals
They are seperate urinals but are all joined together with dividers between them. So there are 3 spreaders. I'm trying to upload a photo but can't do it!
dont know if they are still available but there used to be spreader heads with a screw through the middle either drill into the slabs or break the old ones away and reuse the hole if theres a bolt it should punch through
We need that pic.
The forum had a bad attack of spamming a while ago, so the security settings are at defcon 2 at the moment, meaning that members with a low post count can't put pics up.
Maybe put it on a flickr account and link to that?
The last time I did this was a long time ago but the hotel owner was well pleased with my work.
I did the whole lot in copper (polished each day) with loads of top quality saddle clips as fellas use the pipework to climb up on to the step. The spreaders are available from armitage shanks or just make them up yourself out of copper cap ends its dead easy.
Forget getting around the back no chance CHk
Reply to fitting new pipe and spreaders to vintage urinals - but can't get in behind them! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi everyone I hope you can help. We were getting some work done and our builder attached the boiler condensate pipe to the sink waste pipe. This...
I have seen people speaking of this and others not understanding. I have a leak in my pipe coming from the main. Attaching a new 1/2" coupling to...
Hi All This is following on from thread I made a few days ago but can't seem to find I'm in a bit of a bind with my CH design where I want to...
A
Hi, I am replacing a leaking push fit flexi tap connector under the bath with a compression fitting flexi. The problem is that the old pipe seems...
Hi, hope all is well! I’ve fitted a compression cap on two of my shower mixer copper pipes (15mm). One of them has scratches and burring and is...
