Discuss fitting a 3-way T valve, what flexible hose to order? in the USA area at PlumbersForums.net
I'm new to UK plumbing system and got lost as don't know names/diameters/availability of the parts I need to do the job.
I guess I'd need to remove one of the copper fittings and order a flexible fitting of some sort and diameter. Don't worry about the length I would get a suitable one.
I'd like to insert one of these T-valves inline so that I can connect a shower head to one of its 20mm ends
Here are the two T-valves I got here (I only need to insert one inline)
And here it's where I'd like to insert the valve.
What are the names of the parts/fittings I would need.
Much appreciated
What’s the flexible hose / shower head for ?
due to uk water regs you cant install one of those off cold mains water due to the risk of backflow, needs to be done properly with a break tank with weir, shower booster pump, under sink water heater and tmv3
Reply to fitting a 3-way T valve, what flexible hose to order? in the USA area at PlumbersForums.net
Hello guys, a couple of months back I installed a new shower and sink into a part of the house that hadn't previously been plumbed in. This forced me to run some pipes outside the walls, so I put in stopcocks at the point where the new pipework joins the old Just In Case. I used copper pipe and...
Hi all, I need to order a flexible pipe to connect this vessel up with. The pressure vessel instructions don't mention the thread size? A 22mm pipe almost fits over the threads so I assume it's 3/4 BSP? Does that sound right? The other end goes to the valve, will a flexi like this...
Hi, I have a 25mm plastic (HDPE?, MDPE?....blue) pipe that comes into my shed and i'd like to run 2x flexible hose connectors off it. The internal diameter of the flexible hose connections looks to be about 20.9mm. What would the pros recommend?
1K
Hey guys in the know. I have paid for a heating and plumbing contract and had to pay my excess 3 times for the same thing still not fixed. The issue is quite simple to repair not sure why any one of the 2 plumbers could not fix it. Why am I paying for cover. The auto air vents in part of the...
Hi All, My first visit here in quite a while and it's in part to share the news that I have finally gone over to the dark side! Although my 30 year old Baxi back boiler was still going strong, I've finally succumbed to pressure from Mrs RWD and had a Combi installed. The Heating Engineer that...
