Hello men,, been meaning to get back to u all, but my 2 year old son has been ill with a sickness bug and havn't been able to get on the laptop.. anyway im very gratefull for all your comments and have taken everything u've said on board,, im also gratefull that you didnt go to hard on me lol.. i know its not the prettiest and there's lots of things that i would do differntly after reading your comments, im gona buy a daimond core drill set from screw fix 2moro, so i might go back and put the waste on the outside as it irritates the hell out of me being that high up, also if i had more time i would probably have lowered the hot and cold water pipes and droped the pipes behind the skirting boards and boxed them in using the skirting.. but couldnt really afford to do that much work.. as i have my other work to get on with, which is how my interest in plumbing come about.. Every radiator i take off allways seems to leak and one day i took off a relitively newly plumbed in rad and it was leaking from everywhere, so my old man had to come out and drain the system down, and solder a new bit pipe in.. and since then ive gone plumbing mad, reading books, watching dvds, videos on you tube, i read on here most nights plus im in colleage in the evenings doing level 1 at the minute.
Going back to one of the comment, the fella who was ment to have done the work, imo did a good job on the other bathroom but was being rushed by his boss, and was working quickly enough.. The reason the firm was thrown off the job was beacuse one of the pipes chased in to the wall in bathroom started to leak, also one of pipes connected to the rad in the toilet that i was working in blew off and flooded the down stairs,, the house was being renovated at the time so nothing got damaged.. plus the bath trap/waste leaked and damaged the kithen ceiling,, but apart from that everything else was fine.. and i put it down to the fact that the fella's boss was always trying to make him work faster.
after reading all your comments i went out and did some reaserch and the only one thing i couldnt figure out, is how to connect copper staright to a monoblock tap with out using flexis? also those flexis that i used were the one that came with the tap so i just used them. plus someone mentioned about connecting the waste to an 4'' extention, would that be done using a strap on boss? thanks again.. pipeline
