Discuss Ferroli Modena in the Plumbing Jobs | The Job-board area at PlumbersForums.net
bewsh
Alright guys?
looking at this boiler for my mate.
no heating or hot water, light comes on with demand, pump runs with heating, but no fan. Checked thermistors and they were ok so checked fan a bit more, 0v between l and n to fan, 240v between l and e to fan, 240v between n and e. i think some of these ferroli boilers have a switched neutral to the fan. Would you say this is a pcb fault? Polarity and electrical checks all good.
Is this a variable speed fan? Check pins on PCB just incase it's harness. Not sure bout n to e 240. Could be fan motor is pooped.
Nah single speed fan.
It's strange because it's intermittent, so can't imagine the coil is buggered. Think I'll speak to ferroli tech tomorrow. Checked voltage from pcb, still the same.
Ye fan spins freely when it's not working. Didn't check resistance across fan coil.
Strange how it's an intermittent fault though.
Just an update guys:
Traced fault to the aps - sticking after in closed circuit when the fan goes off. PCB checks aps before it switches the neutral to the fan, job done, luckily didn't order PCB !
Reply to Ferroli Modena in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Locked
Hello, I have a ferroli falcon 2 boiler (yes it is pretty old). A few days ago the hot water started going hot and cold when running. Monitoring...
    • Funny
    • Optimistic
Hi, I've got a ferroli 901 boiler, I initially thought the pcb was at fault so bought a new one and I'm having the same problem ( has been...
Ferroli 32c he (combi) So after having a 2 week holiday, we have come home to no hot water. It just cycles on off every second. Heating working...
I have a Vaillant Turbomax with an F29 fault. When there is a demand for hot water the gas ignites initially, and the water is heated. However the...
Deleted member 120897
I need some help with a Worcester Junior 28i gas boiler and I'm hoping someone here may have came across this fault before ... I have checked...
1K
