Discuss Ferroli Modena 80e DHW problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
audistorm
Good evening folks, We have a Ferroli Modena 80e boiler in our house and I am looking for some advice and also a good ferroli engineer local to Birmingham. We have been in the house for 5 years and initially we would get a reasonable supply of DHW, the CH works absolutely fine by the way, The DHW in the summer is ok (when the CH is off) but to fill the bath you need to run the hot tap on very slow demand to allow the boiler to heat the water to a hot temperature. In the winter to run the bath to obtain hot water and not luke warm you have to run the hot tap slowly or if you have a shower you need to run the cold tap in the nearby sink to reduce the flow again to obtain a hot temperature, the shower is a thermostatic shower. I have had some engineers out in the past (BG and a ferroli engineer recommended by the BG man) but they just changed the two thermistor sensors , this hasn't fixed this fault. We have just put up with it over the last two years as it only really is affected in the winter with the colder input water supply but the cost of gas is forcing me to get this problem fixed. I think it may be one of two problems, one the DHW heat exchanger is not working efficiently (Bham being a hard water area I wonder if it is full of scale, or could it be the DHW flow valve sensor valve. I would love to replace the boiler but cannot afford to do that hence I would love to find an engineer who is good with these boilers, I know these are old boilers and hence limited to technical expertise. Please share any help or advice please. Hot water pressure is not as strong as the cold fdor obvious reasons but it is quite good, just luke warm even with the hot water burner control on full.
It's a shame that no one has replied to my post.
i am looking for an engineer to come and fix our boiler, it's just that I didn't want to either waste your time or mine if you were not experienced with them. I know from experience that not every one likes to work on these.
if I can't find an engineer we may look to save up and change the boiler out for a new one, rather than waste money on this boiler, in which case I will need an engineer to change the boiler., live in Sutton Coldfield.
i think I may have given the impression that I was just after the fix to sort myself. Sorry if that was the case.
Could you recommend a replacement for our Modena, something with a similar output, but more efficient please
You have a large choice as far as boilers are concerned, all will be about the same efficiency wise, asking on here you will get several answers as we all have our opinions on what is the best boiler, look at length of warranty and what the back-up is like for the boiler of your choice , Due to the cost & availability of parts for you excising boiler have you considered calling Ferroli out on a fixed price repair, sometimes this is he best solution .
Reply to Ferroli Modena 80e DHW problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Locked
Hello, I have a ferroli falcon 2 boiler (yes it is pretty old). A few days ago the hot water started going hot and cold when running. Monitoring the boiler, the demand light works fine. When the water gets up to temperature every 10 seconds or so, the boiler stops for a fraction of a second...
I have a very strange issue with my BAXI 105e DHW. if i turn on the hot tap the pump starts and demand for DHW is shown, after a some seconds it will show an error, 60 degree, pump or flow. Well switch the tap off wait maybe fifteen seconds turn tap on and low and behold hot water. If after a...
Hope someone can offer some help with this issue, I have a Baxi 105e works fine no real downside, serviced looked after regularly. Have an issue with hot water, open hot water taps runs cold and indicates on boiler 60degrees or pump or pressure problem. Leave it ten seconds open taps again low...
Hoping someone can please help. I have an intermittent fault with my electric hot water. I have an older style electric hot water service that heats on controlled load over night. The large tank is in roof space of 60s built villa unit. Every few mornings, no hot water will come out of...
Ferroli 32c he (combi) So after having a 2 week holiday, we have come home to no hot water. It just cycles on off every second. Heating working fine and have to use it for the water to be hot. No fault codes. Clicking noise in the pcb on trying for hot water? Things I have checked. Diverter...
